Ok so i am currently running an fx 8350 OC to 4.5 ghz. The power supply the i am currently running is a corsair cx500. what i am wondering it why other people with the same specs are getting 100% gpu usage. Iv seen the 8350 and gtx 980 work together just fine. All i come up with when searching is that my cpu is bottle necking the gpu. I found that hard to believe as every forum says somthing different. So what is going on is I buy a 980 super pumped to throw it in to find out wow my 750 ti worked 1000 times better. The gpu will not use 100% usage or it power usage unless im running benchmarks. however in game the gpu sits at 40-60% and as now as 20-30. Meanwhile the cpu is at like 60% max. when this happens. So if anyone could help that would be awsome. i dont want to throw my gtx 750ti back in. Also im being told i dont have enough ram? I will post my specs and hope for some help here lol. Im ready to dump buck on a new system to hopefully run this card. I see other running the cpu gpu combo and getting awsome usage and frames. I sit at low usage and struggle to hit 50-60 fps with hard drops of 30-20. If psu and Ram are my issue wich is what im expecting please someone let me know.
My specs
Gigabyte 990fxa-ud3
AMD fx 8350 at 4.5 ghz
8 gig of hyper x memory hyper x hx316c10fbk2/8
Corsair cx500w psu
gtx 980 sc acx 2.0
Corsair H100i water cooler
and two samsung evo ssds
My specs
Gigabyte 990fxa-ud3
Corsair cx500w psu
gtx 980 sc acx 2.0
