I have connect PC to external moniter.. It was working but went out and would not show on external moniter so I took battery o
Americanmade
No picture coming up on external moniter previously would work then it went back to blank. safter trying to get it to work and no luck I took battery out and put it back so I don't know whats on screen and no picture on external moniter...what can I do to fix this problem...any suggestions are appreciated.
Hi,
Does the built in screen work? If it does please do try these troubleshooting steps that may help in solving the issue.
- Start by uninstalling/reinstalling the graphics driver.
- Go to Device Manager and uninstall the graphics driver.
- Do also check Programs and Features and uninstall anything related to your graphics card.
- Next is to download and install the latest driver from the manufacturers site.
- Once the latest driver has been installed reboot your laptop.
- After the reboot do test it with your external monitor again, press the Windows key + P at the same time and select between Extended or Duplicate display then press Enter.
- If these doesn't work you may need to try a different cable or try it as well into a different monitor.
