i have HP Compaq 8200 (240W PSU), can i add 1030gt with fan? or i need one with fan casue of the low psu?
adarc8
229
Hello i have HP Compaq 8200 elite with 240W, ppl told me to buy 1030gt and i saw it has pretty nice performance. my question is can i buy this version?
https://www.newegg.com/global/il/Product/Product.aspx?
Item=N82E16814137139&cm_re=1030GT-_-14-137-139-_-Product
im afraid it wont work right because it has a fan with cause the gpu to "ask" more W from the psu and so it will be too much.. i heard someone telling me go for the low profile the one without fan so it wont be requiring too much from the PSU.. but this is the cheapest version i found.. can i use this anyway?
If you're sure that your PSU has those same +12V specs as the one in the photo, you could even go with a GTX 1050 Ti low profile.
I have the Zotac in my Optiplex 790 SFF. It is running fine on a PSU with poorer specs than yours. Being the shortest of the ones above, it would be a sure fit in your machine.
yeah it will never fit in, itried to fit in my mini 960 gtx which looks like this 1030gt in the picture, and it didnt fit.. i guess i need low profile..
and yes im pretty sure this is the psu i own..
any card that has no 6 pin connect i can put in this pc? i just found Palit GTX 950 which looks like no any 6 pin connect..
https://www.youtube.com/watch?v=hTcpBFbJ-jw
can my pc run it?
can my pc run everycard which have not other connect execpt from the 16x motherboard connect..?
what im suppose to do with this information bro? i asked a question if i can run this Palit 950GTX.. i dont understand ur answer..
Unfortunately you can't use a gtx 950 because it draws 75-90W depending on the model. What the 25W limitation means is that you are very limited to what GPU's you can use in the Elitedesk 8200 SFF.
No, the GTX 950 would demand too much wattage at load. The GTX 1050 or 1050 Ti would be the most I would go. Or your original GT 1030 choice if you want to play it safe.
