I have monitor with only VGA output and GPU 1060 with DVI and HDMI input?
nino.k
What convertor should i use if i need to, VGA to DVI or VGA to HDMI,
please guys give me some tips what is my best solution... thank you
Barty1884
Retired Moderator
The "best" solution is likely going to be a new monitor. Anything that solely has VGA is going to be pretty dated at this point.
They don't have to break the bank either:
Monitor: LG - 23MP57HQ-P 23.0" 1920x1080 60Hz Monitor ($99.99 @ Newegg)
Total: $99.99
Generated by PCPartPicker 2017-11-17 10:57 EST-0500
If you want to continue using your existing monitor, you need an "active" adapter to convert the digital signal (DVI-D or HDMI) to analog (VGA).
https://www.amazon.com/Rankie-Gold-Plated-Active-Adapter-Converter/dp/B00ZMV7RL2/ref=sr_1_3?ie=UTF8&qid=1510934307&sr=8-3&keywords=active+hdmi+to+vga&dpID=41M6cII-WlL&preST=_SY300_QL70_&dpSrc=srch
Barty1884
Retired Moderator
Total: $99.99
Pat Flynn
231
15
18,765
46
If your DVI port has a '+' at one side of the pins with 4 pin holes around the cross, then it supports using a DVI-to-VGA adapter. This is the simplest and cheapest route to connect your monitor to the video card. If it doesn't have that cross with 4 pins, you'll need the active adapter listed above.
Barty1884
Retired Moderator
Modern cards (10 series, RX etc) are digital only. HDMI, DP, DVI-D (Dual Link). No analog signals included. "Active" adapters are required.
