I have no sound
Brian
1,371
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
For the last few months I have had an intermittant problem
on my XP Home. I keep loosing the sound and it has got
progressively worse I have checked through the normal
things that I think could be the problem and can't find
anything. Any ideas please.
Brian
G
Guest
Guest
Reinstall the sound card drivers. Use Everest Home from www.lavalys.com
to find out what sound card you have and it should also provide a link
to the drivers. Also, double check that the card is well seated in the
PCI slot (if it is a PCI Card), double check the jacks and plug. Make
sure the contact is being made properly.
Nathan McNulty
> Brian
G
Guest
Guest
Brian, what are you using for sound? Integrated sound chip on
Motherboard? Pci Sound Card?
"Brian" <brianjudge67@msn.com> wrote in message
news:124e01c49d8a$054df7e0$a501280a@phx.gbl...
> Brian
Thread starter Similar threads Forum Replies Date
S Windows XP 2
Similar threads
