[SOLVED] I have problem with integrated Vega 8
lukat
Commendable
Jan 4, 2021
Hello guys i bought a new lenovo legion 5 with an Rtx 2060 and Ryzen 7 4800u and integrated Vega 8 as it says.
The thing is it wont let me install ryzen 7 4800u drivers from the website and i dont know how to chamge betwen integrated and dedicated gpu. Btw everything else works great, but it has poor performance and battery life when unpluged and it doesnt say anywhere anything about my vega graphics.
Any help would be great.
The weak vega integrated graphics is the default gpu when not plugged in.
That is done to save battery run time.
The nvidia driver control app may have an option to pick which adapter you want to use and over ride the default.
If you want performance, game while plugged in.
Running on battery will also normally reduce the cpu performance to conserve run time.
You can find those settings in windows power management.
