I have an iTX form factor computer (I will list links to the parts on newegg for reference), but currently my intake fans are 2 from my GPU and one that runs through the CPU radiator. The consequence is that unless I force the CPU fan to run in overdrive, it is hard to get cool air into the computer when both the GPU and CPU are under high load. I've tried reversing the CPU cooler fan to pull in hot air from the graphics card, but that only hurts the temperature readings.
Cooler master suggests flipping the PSU to allow it to play a role in exhaust, but I have a noctua 80mm fan that seems to push most of it out
I also modified my case to have vent holes in between the PSU and GPU as well as reducing restriction on the GPU fans and adding mounting for the thicker 80mm fan used for exhaust.
Does anyone have any ideas for either cooler intake somewhere or possibly an idea as to whether the hot air flowing through the case could damage motherboard components over time?
Parts:
Case https://www.newegg.com/Product/Product.aspx?Item=N82E16811119286
GTX 780 https://www.newegg.com/Product/Product.aspx?Item=N82E16814121779
i5 4670K CPU
CPU water cooler(closed loop) https://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
Motherboard https://www.newegg.com/Product/Product.aspx?Item=N82E16813132039
then the rest is gaming ram(not overclocked), a HDD, and an SSD to boot from and play games
Parts:
i5 4670K CPU
