I have sj5 sound bar, it possible to connect tv and dvd player to sound bar using 1 in 2 way out adapter
Your soundbar has three inputs. You can use a different input for each source. How you do that will depend on what connections you have on the TV and DVD. You could use optical for the TV and HDMI for the DVD. If you want to use the aux input then an audio input selector is what you would use rather than a Y splitter.
https://www.amazon.com/Stereo-Manual-Selector-Sharing-Switch/dp/B00NTJET10
Connecting the DVD to the soundbar directly allows for CD playback without turning on the TV.
Latest posts
