wanted to know if there was a way to keep the loop attached to the fan where the 2 pin led wire is supposed to connect? if i can do that will that be ok for the the fan to operate i don't really care about the leds being too bright. also when i would want to plug in the led wire if i wanted to use it, where would i put it?
my case is the Apevia sniper2-RD case. and my motherboard is the asus 970 pro gaming aura. my power supply is the FSP Group PT1000FM item is the order they are listed.
http://www.newegg.com/Product/Product.aspx?Item=9SIA3912DB6332&cm_re=APEVIA_X-Sniper_X-SNIPER2-RD-_-11-144-288-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA1N83ZH4959&cm_re=asus_970_pro_gaming_aura-_-13-132-713-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16817104192
