Question I have Thermal throttling?
Oct 1, 2022
7
Hace poco actualice mi pc a i5 11400, 16gb ram 2666mhz, MB b560m a pro msi, rtx 3060 12gb oc, 600watt psu, pero mi cpu cooler es viejo y tiene un maximo de 40watts en tdp, en pubg todo en graficas medianas tengo cuelgues de fps de 140 a 80 no es normal para mi pc, y vi las temperaturas y el procesador en 40 de uso maeca temperaturas de 100 grados, en inactividad el procesador marca 50 grados eso no es normal no? Cuanto debo subir en oung en graficas medianas, crees que al actualizar mi refrigeracion los fps suben y van sin cuelgues?
Zerk2012
Ambassador
I recently updated my pc to i5 11400, 16gb ram 2666mhz, MB b650m to pro msi, rtx 3060 12gb oc, 600watt psu, but my cpu cooler is old and has a maximum of 40watts in tdp, in pubg everything in medium graphics I have crashes of fps from 140 to 80 is not normal for my pc, and I saw the temperatures and the processor in 40 of use maeca temperatures of 100 degrees, in inactivity the processor marks 50 degrees that is not normal right? How much should I go in oung in medium graphics, do you think that by updating my cooling, the fps go up and go without crashes?
Why would you even use a 40 watt cooler on that processor? What happened to the cooler that came with the 11400.
