Question i have this problem:Critical Kernel-Power, Event ID 41, Task 63
mihgeo
45
hello all,i have problem with pc is from software or hadware?i make test ram and is good...
EventData
BugcheckCode26
BugcheckParameter10x41790
BugcheckParameter20xfffffa80062f3e50
BugcheckParameter30xffff
BugcheckParameter40x0
SleepInProgressfalse
PowerButtonTimestamp0
event 41 (63) is a reaction, not a cause. When windows starts up, it runs a report to check if it was shutdown right the previous time. If it finds it wasn't, it creates event 41
https://docs.microsoft.com/en-us/windows-hardware/drivers/debugger/bug-check-0x26--cdfs-file-system
not an error code I see a great deal... one solution suggested in link above is to run chkdsk C: /f on the boot drive (cmd as admin), likely need to run at startup since it doesn't like running it in windows.
the pc crash-restart and after restart i view this notification,two times in one day
I am not sure if the code i thought was BSOD code is, so can you go here and then choose step 6 below it and set up PC to create minidump files
that creates a file in c windows/minidump after the next BSOD
copy that file to documents
upload the copy from documents to a file sharing web site, and share the link here and I will get someone to convert file into a format I can read
