I have two fans but only one 4 pin cha_fan
dachinatroshvili
19
guys i currently have asustek H110M-K (LGA1151) motherboard and i have two fans. i want to plug both but there is only 1 ,4 pin cha_fan but under it there is 9 pin "thing" is it cha_fan too? there isnot name written on it tho. help
SOLUTION :)
https://www.amazon.com/PWM-Y-Splitter-Cable-Adapter/dp/B002OFP6QW
Fan splitter , run 2 fans from one header.
You only have 1 fan header.
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x Chassis Fan connector(s) (1 x 4 -pin) .......Here
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x Clear CMOS jumper(s)
1 x 14-1 pin TPM connector
Look in your user manual for your motherboard, as all ports are labeled. From what I am seeing, the "9-pin thing" you are looking at is most likely an internal USB port. That is NOT a chassis fan port. Your motherboard has support for just 1 chassis fan plugging directly into the motherboard. You can give the other fan power using a 4-pin adapter (such as this for SATA connections or this for Molex connections).
