sonexpc Honorable Feb 20, 2012 478 0 10,860 Feb 23, 2012 #2 What computer you have and is your monitor have build in Speaker...? Upvote 0 Downvote
C c7875w11 Distinguished Jun 26, 2011 4 0 18,510 Feb 23, 2012 #3 yes my monitor had build in speaker Hp vs15......computer HP workstation xw6000 Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Feb 23, 2012 #5 Did you plug in the speakers to the computer (not the video cable, the audio one)? Volume on them turned up? If you can hear the sounds form the PC tower, means you have not hooked up anything to the audio outputs. Upvote 0 Downvote
sonexpc Honorable Feb 20, 2012 478 0 10,860 Feb 23, 2012 #6 here is a quick spec.... http://h18000.www1.hp.com/products/quickspecs/11485_na/11485_na.html because you use a workstation it have the on board Audio connect to a inside speaker... In the quick spec it say it also have "Sound Blaster Audigy 2 ZS PCI card" You need a Audio cable connect from the "Sound Out" on System to Audio In in the LCD.. You monitor seems didn't come with the Audio Cable http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00655637&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=459838 Upvote 0 Downvote
