Okay I so finally pulled the trigger on some A-RGB fans (4 ×artic p14, 2 x artic p14).( In the process of trying to get my gpu out I broke the little pcie clip that snaps when it's installed all the way. ) I also removed all the other case fans ( 2 lian li 140mm and 1 120mm lian li kept these ). After plugging everything up and turning the on the pc, i noticed the red cpu light on the motherboard was on amd it wasnt posting ( also noticed my gpu fans weren't spinning. Below is everything I've done. Please help!
1. I made sure the cpu fans were plugged up correctly
2. re-seated ram
3. checked cmos voltage
4. re-seated my gpu made sure it was being held up by its support.
PC specs:
CPU: Amd 7700x
GPU: powercolor red devil 7900 xtx
Motherboard: MSI Pro B650p wifi
Ram: Gskill Flare X 5 DDR5-6000
PSU: CORSAIR 850e
AIO: deep cool 520lt
2. re-seated ram
PC specs:
CPU: Amd 7700x
PSU: CORSAIR 850e
