i installed a 2nd SSD drive in my system and it will not boot. Each drive works fine on its own, but not together?
Alan_22
My system fails to boot when I attempt to use a Vertex OCZ 128GB SSD drive with Win7 on it and an Intel 250GB SSD also with Win7 on it. The OCZ drive is SATA1 and the Intel is SATA2. They just will not work together...anyone know why? Thanks.
Uhh look at you mobo manual. It should tell you the Sata cable order (Sata 1, Sata 2, Sata 3, etc.)
You want the load order to be lowest to highest. So in your case, you want the 120gb plugged into the Sata 1 port as its capacity is lower than the 250gb which you will plug into the Sata 2 port.
Hopefully that works.
If your OS is on the 250gb go into your BIOS and set it to boot off of that hard drive if its on the SSD you should be good.
