Sooo I just finished my first pc build and the case im using is an Enermax Ivektor black which has 2 built in fans, both of which arent spinning at the moment. my processor fan and graphics card fans are spinning. when i go to bios under hardware monitoring ( i think thats what its called) it says: CPUfan 5000 rpm (around) then under that it says sysfan1 0 rpm. my system temp is around 40c and cpu temp is around 30c. what should i do? also why arent there two fans rpms in bios?
(btw is this under the right category?)
