i just made me a gaming pc and need a little help
Jeffrey Sterling
30
i aim to play skyrim on max settings
rosewill challenger case usb 3.0
Rosewill 550W 80 PLUS BRONZE Certified
MSI A78M-E35 FM2+ / FM2 AMD A78 (Bolton D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
G.Skill Ripjaws Series 4GB (2 x 2GB) SDRAM DDR3 1600
EVGA GeForce GTX 660 SUPERCLOCKED 2048MB GDDR5
AMD Athlon X4 AD750KWOHJBOX 100W
Western Digital Caviar Blue 500 GB SATA III 7200 RPM
will the cpu handdle the video card i heard that if the gpu does not have a good cpu it wont get its full potential
my budget is 500 600$ and this came up too 566.87
Could you list where you are getting your prices and which stores that you might be able to purchase from?
It is easy to talk about max out without setting limits for what resolution you are going aiming for and if you will use any mods that might be demanding on CPU vs GPU. Make a list of those mods that you might aim to use, especially those that you think will be visually demanding and then you have to find a balance between what you can afford and what you will be able to max out. Your budget constrain are extremely low, so don't expect too much.
This actually would be better for a bit more.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor ($118.93 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard ($49.99 @ Mwave)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($52.00 @ Amazon)
Video Card: Asus GeForce GTX 660 2GB Video Card ($189.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ NCIX US)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($54.99 @ NCIX US)
Total: $580.88
(Generated by PCPartPicker 2014-04-10 20:19 EDT-0400)
