Question i just wanna know if these will work togther with no problems at all
Jun 18, 2019
71
CPU : Ryzen 5 2600
GPU : Sapphire Nitro+ Rx 580 OC
Gigabyte B450 GAMING
8GB ram ddr4 (1x8)
Seasonic 80+ bronze 520W
thanks
R_1
Judicious
Herald
as it no worries it will work.
however one little tweak could net more memory performance.
do not get a single stick of RAM, get a matched set, sold in a pack together. you can then enable Dual-channel RAM and ryzen loves it more bandwidth. get a base speed of 3000 for the RAM as that is where ryzen seems to live.
Jun 18, 2019
71
is a single 8gb speed of 3200 good enough? becuase i don't have the budget for two of them..
but i can get another 8gb later tho
R_1
Judicious
Herald
its better than nothing.
later do not add to, replace. mixing ram modules is a gamble every time. the units sold in kits are made to work with each other, the chips on each are tested and mated with each other.
I suggest selling the RAM and buying a matched set if you need to upgrade later.
Latest posts
