I keep having to disconnect and reconnect from my wifi every 10 minutes?
Freeeasy
4
So, i play a game called League Of Legends, and sometimes i will have trouble with my WiFi just getting into queue, whenever this happens i have to disconnect and reconnect to my WiFi and everything works for 10 minutes before i have to do it again, and this isn't just that particular game. Just browsing on YouTube the video will randomly stop and i have to repeat the same process. Idk what is going on, I've tried to look this up on this website but nothing worked. If anyone has any ideas or needs the details of my laptop/router or whatever please let me know so i can hopefully fix this issue
When i did a speed test it said i had 150 mbs, and my computer diagnostics said 860 mbs, so i dont think it is the connection, also i'm only like 50 feet from the router so it can't be that weak
No, my phone works fine with the same wifi
Try to recycle the router and modem by disconnecting everything for about one minute. Everything means the cables and electrical connection to both items. Reconnect and see what happens. Also check your router for any bios updates. Check your Ethernet adapter for any updates also. These are all simple trouble shooting techniques. Make certain that your wifi connection is secure with some type of encryption. You do not want other people pirating your bandwidth on an unsecured connection. Sometimes........routers will crap out like any other electrical device. Stuff happens.
ok so i went into my device managers on my laptop, and updated both of my wifi things, one is the actual connector and one is the controller, when i went to update the connector, it said that there wasn't any updates to be found, but i did find one for the controller so ill see if that helped.
Recently i am facing simillar issue. WIFI works fine at home, for office, needs to disconnect and reconnect every few minutes. My phone, smart tv is running normally on the same router. Seems my laptop and office router have some clash issue, i already tried with assigning static ip. Also checked for any driver update but no success.
