Question I messed up when applying thermal paste and need advice ?
deadrush
299
4
18,815
9
I accidentally got thermal paste on my Ryzen 3600x pins and in the mobo socket, now my pc lights come on but no video signal or anything beyond this. Is it possible i destroyed my pc or if i clean it will it be fine ?
deadrush
299
4
18,815
9
I can later its not bad i got most out but there is a little bit between the pins on cpu and im not sure if there is any left in the socket and im not sure how i can check
What kind of paste was it? If the paste you used was conductive……
If the paste was not conductive and you can fully clean the cpu and socket with isopropyl alcohol and let them dry, maybe you have a chance? But if the thermal paste was conductive, arctic silver 5 for example, your cpu and board are probably gone.
punkncat
Dignified
Ambassador
I would take the mobo completely down and use some brake parts cleaner to get the paste out of the socket area. Spray it down with some multi purpose spray, blow it off really well. Probably a good idea (after that) to attempt to boot the computer fully outside the case "breadboarded" as we call it. Make sure to set the motherboard down on something non conductive, such as it's box.
For reference, see TechYesCity (YouTube) and look specifically for what he calls "The Tech Yes lovin'"
deadrush
299
4
18,815
9
Ok i think i can clean the cpu but if not i have replacement on it but the mobo i have nothing so i guess worst case i buy new mobo
Also how would my pc react to starting it with thermal paste on cpu pins and socket?
