I messed with the cooling fan
talal_tariq
Commendable
Mar 29, 2016
12
I messed up my cpu heatsinks and now the pc wont work that well.. basically i can go into bios and stuff but when the windows starts running it instantly crashes (i installed win 7 from win 10 thinking maybe it was the softwares fault as the same happened with win 10). My worst mistake is accidentally running the PC without the heatsink.. i took it out for cleaning and forgot to put it back in.. it only ran for 13 or so seconds.. the processor is an i7 and the motherboard is a gigabyte.. any and all help will be extremely appreciated
Im not sure if the cpu is fried
I accidentally broke one of the pins too.. it works now but keeps crashing constantly. Cant even handle Internet explorer without overheating.. cpu thermometer shows all 4 cores have temperatures around 90-100 celcius.. it even goes above that.. usually stays at 98
