"I already have it plugged in"
You already have what plugged in? You must learn to be less vague when you post for help.
If you are setting up this router for the first time, go in to it's configuration utility to check that it's actually connected to the internet.
Also check that all the lights on the router are showing "OK" (usually a steady green, not blinking).
You can also restart the router, that might fix the problem.
