Question I need a 12100F GTX960 Monterey EFI
Jan 8, 2022
8
I prepared 2 USB stick. First i installed USB 3.0 Monterey 12.3 and on second USB 2.0 flash disk i installed Monterey 12.6. But i dont have any good EFI file for work on them. I tryed some EFI files. First i take code error and was i trying second try i take block image. And i tryed front and back USB slots, and thats not work. I know my GPU is will not work good in Monterey but some peoples made patch for home use web patch. Can someone look my EFI? I dont know make EFI well. By the way sorry for my English if i make mistake.
https://disk.yandex.com.tr/d/52ozSKFtlVuGHA
https://github.com/dortania/OpenCore-Legacy-Patcher/releases
i3-12100F
Asus Strix GTX 960 2GB
MSI H610M-B
8x2 Crucial Ballistic 3200MHz Cl16
I did not (full disclosure) download anything from either link that you posted so I cannot comment on your EFI.
However, there are sources for more information.
Perhaps the following links will prove helpful:
https://www.lifewire.com/fix-failed-installation-of-macos-monterery-5211043
https://www.efi.com/marketing/fiery-servers-and-software/campaigns/macos-monterey-compatibility/
Sorry,
https://drive.google.com/file/d/1ALwDi6C4RsYk1HzZM_DPBFWEQz5gValY/view?usp=sharing
Your English fine.
I simply do not download .zip files from basically unknown sources especially when the zip file contents include things like "BOOTx64.efi".
Which I cannot test anyway...
I will have to defer to those who are able to download the file, unzip it, and execute the code.
Reactions: Alm_06
