I need a air/liquid cooling to my pc
Yazan Zaid
290
I need an air/liquid cooling to my pc,
Processor: intel core i7-4930k
Memory: Corsair Vengeance 16GB (4x4GB) DDR3 1866MHz
Motherboard: Rampage iv black edition/extreme
Graphics card: MSI NVidia Lightning GeForce GTX-770
SSD: still dont know
HDD: 2xWestern Digital WD1003FZEX Black
Optical drive: Sony SATA 24X 5280S-CB-PLUS Burner Drive CD DVD Writer DVD+R DL Overburn 8.7 GB
Cpu cooler: ??
You can discus on my spec.!
I've heard about nitrogen cooling, what's is that??
Yeah you only need one. The Noctua is the best air cooler, and the H100i is one of the best water coolers. It just comes down to preference at that point. If you feel safe running water (I would, and so do many others) or if you can put up with the Noctuas, offsetting appearances.
I recommend you defiantly get that ssd (so fast)
And you should probly go for an water cooled AIO solution i recommend the swiftec h 320 or 220 depending on your case!
Or even the h100i it all depends on how much money you want to spend.And are you overclocking? Oh and nitrogen cooling is for the extreme overclockers and not practical for the a desk top pc.
50~160$
What ssd are you talking about?
You should be able to oc with all the mentioned cooling solutions d14,h110,h100i,But you will get better cooling results with the swiftec 320 or 220 its currently the best performing liquid AIO on the market at the moment.
You said SSD: still don't know? So i thought you hadent made up your mind on getting an ssd. An ssd is one of the best upgrades you can do to your pc in my opinion! SSD's are BEAST!!!
