Varzoh Honorable Aug 12, 2015 161 0 10,680 Aug 19, 2016 #1 I need a chromebook for school. All I need is a inexpensive laptop, one that is capable of searching online, long battery life, and has a hdmi. Under $250 I need to be able to use another monitor with it.
Solution basroil Aug 21, 2016 Varzoh : I need a chromebook for school. All I need is a inexpensive laptop, one that is capable of searching online, long battery life, and has a hdmi. Under $250 I need to be able to use another monitor with it. Do you NEED chromeOS or just heard about that horribly useless system? If you don't, how about http://www.newegg.com/Product/Product.aspx?Item=9SIA24G41F9926 with an sd card for storage?
woodson75 Distinguished Feb 5, 2013 847 12 20,015 Aug 21, 2016 #2 Something like the ASUS C201PA-DS02-PW Chromebook might be a nice solution. $200 gets you a quad core processor, 4Gb RAM, micro-hdmi Upvote 0 Downvote
basroil Glorious Oct 19, 2013 8,698 1 46,960 Aug 21, 2016 Solution #3 Varzoh : I need a chromebook for school. All I need is a inexpensive laptop, one that is capable of searching online, long battery life, and has a hdmi. Under $250 I need to be able to use another monitor with it. Do you NEED chromeOS or just heard about that horribly useless system? If you don't, how about http://www.newegg.com/Product/Product.aspx?Item=9SIA24G41F9926 with an sd card for storage? Upvote 0 Downvote Solution
orlbuckeye Distinguished May 1, 2009 1,543 1 20,165 Aug 22, 2016 #4 Go look at Best Buy they have many. Upvote 0 Downvote
