I need a complete system build
ReneMDube
Commendable
Mar 24, 2016
13
I'm looking for a system build that will rum minecraft and csgo at above 60 fps. I'm looking for a monitor, operating system aswell for around 1000$ cad
With a monitor, OS etc it get's a little bit difficult.
Assuming you're not looking for more than 1080p.......you could go either way, a lesser GPU with a better CPU or vice-versa. I don't think either option would be bad for your planned uses.
The i3 should be sufficient for both games, and you could always upgrade to an i5 in future.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($155.25 @ shopRBC)
Motherboard: ASRock H110M-ITX Mini ITX LGA1151 Motherboard ($74.50 @ Vuugo)
Memory: Mushkin Essentials 8GB (2 x 4GB) DDR4-2133 Memory ($44.99 @ Canada Computers)
Storage: Toshiba Product Series😀T01ACA 1TB...
Storage: Toshiba Product Series😀T01ACA 1TB 3.5" 7200RPM Internal Hard Drive ($57.99 @ DirectCanada)
Video Card: XFX Radeon R9 380 4GB DD XXX OC Video Card ($264.98 @ NCIX)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($79.98 @ Newegg Canada)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($124.00 @ shopRBC)
Monitor: AOC E2425SWD 60Hz 24.0" Monitor ($157.00 @ Vuugo)
Total: $958.69
Generated by PCPartPicker 2016-03-24 18:15 EDT-0400
Alternatively, the i5 would be the better long-term purchase, and you could upgrade your GPU as/when needed.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($265.45 @ Vuugo)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card ($239.99 @ NCIX)
Total: $1043.90
Generated by PCPartPicker 2016-03-24 18:16 EDT-0400
I didn't include a case in either, as that's 100% personal preference (as long as it fits your components, of course).
