I need a cooler?
life24
16
Hi,
I have a i7-3770 and i'm not going overclock .(Although i can't overclock it )
Now i a need cooler? or stock fan it's enough?
Yes your stock cooler will work but compared to other aftermarket coolers it not goinf to be sufficient. At least from the standpoint of getting the coolest temps possible so as to insure longer component life. Hopefully your ram is low profile. At least for these three recommendations. First is the Swfttech Polaris120, it is only available from the Swiftech website. This will cost around $ 50.00 - $58.00. That is total price. But it will even cool a 4.7 Ghz processor. I am using two right Now. Then there is the Thermaltake Nic 5. Last is the cheaper of the three the, coolermaster Hyper 212 EVO. It is much better than stock but not as good as the other two. But it is cheaper. The Swiftech is the best.
One of the best coolers for higher end CPU's is the Cooler Master Hyper 212 EVO because it's is relatively cheap and quiet. It is a very good cooler, I recommend.
The next step up would be a Noctua Cooler. Noctua products are excellent, and nearly silent. I have the Noctua NH-U12 i paired with an AMD FX-6300 and my CPU temps never go above 55 degrees Celsius. I also never hear the Noctua fans that are included with it. Be Quiet! also makes fantastic coolers.
Latest posts
