ThatPcBuildingKid Commendable Oct 19, 2016 218 0 1,690 Mar 2, 2018 #1 not gonna be ocing have £50/$60 to spend currently have a h55 aio but not satisfied itll be enough
Solution WildCard999 Mar 2, 2018 If your not overclocking the H55 should be fine, try it first then if the cooling isn't sufficient then we can make a better recommendation.
WildCard999 Titan Moderator Jul 18, 2014 21,770 1,936 93,640 Mar 2, 2018 Solution #2 If your not overclocking the H55 should be fine, try it first then if the cooling isn't sufficient then we can make a better recommendation. Upvote 0 Downvote Solution
