I need a gpu for this build and hard drive or ssd?
pearce_pc
108
Right I need a good gpu for this build trying to stay under 100 euros if possible. And a play games like fortnite and rainbow six siege. And I want really good fps. Also will I get a ssd or hard drive. If so Link me one. In advanced thank you very much. Link is for my build
https://ie.pcpartpicker.com/list/QyWF4q
Sorry, but just to confirm, are you asking for a GPU that is good for under 100 Euros? Or perhaps there was a typo to keep the system cost under 1000? If that was indeed what you typed, I would advise staying away from GPU's below that price range. They are NOT worth their price. You could EASILY get better performance with the Ryzen 5 2400G. Just confirm with the seller of the motherboard that it is guaranteed to be compatible with the 2400G out of the box. Otherwise, you might have to contact a local PC shop and have them do a BIOS update (or use AMD's boot kit program). You can also save quite a bit of money by going for less flashy RAM.
This config keeps the high-quality RAM, but allows you to expand to a 240GB SSD AND a 2TB HDD for only 40 more Euros.
EDIT: Build Fixed
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor (€173.95 @ Komplett)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard (€88.36 @ Custompcparts)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory (€178.25 @ Custompcparts)
Storage: Kingston - A400 240GB 2.5" Solid State Drive (€56.63 @ Custompcparts)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (€69.26 @ Custompcparts)
Case: Phanteks - Eclipse P300 Tempered Glass (Black) ATX Mid Tower Case (€70.22 @ Custompcparts)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply (€94.90 @ Komplett)
Total: €731.57
Generated by PCPartPicker 2018-07-25 00:40 IST+0100
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (€189.81 @ Custompcparts)
Memory: Corsair - Vengeance RGB 16GB (2 x 8GB) DDR4-3000 Memory (€194.64 @ Custompcparts)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€49.91 @ Custompcparts)
Video Card: Asus - GeForce GTX 1050 Ti 4GB STRIX Video Card (€228.95 @ Komplett)
Case: Cooler Master - MasterBox Lite 5 RGB ATX Mid Tower Case (€72.27 @ Custompcparts)
Total: €975.47
Generated by PCPartPicker 2018-07-25 00:37 IST+0100
I'm assuming you mean 1000 euros. You could get a better GPU if you drop the RGB.
Sorry I meant 1000 euros or 1100 just a good gpu
meant 1000 or 1100
Ah, that makes a lot more sense. I'll get to work ASAP. Do you want to include the cost of Windows in the build? If not, here's what I'd recommend:
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor (€208.95 @ Komplett)
Video Card: Palit - GeForce GTX 1060 6GB 6GB Dual Video Card (€328.07 @ Custompcparts)
Total: €1094.64
Generated by PCPartPicker 2018-07-25 00:46 IST+0100
Note if you want to save a bit of money, the 1600 is also alright. If you stay with the 2600, ensure that the board WILL be compatible by asking the seller directly.
I can get a kenguin key for 30 40 euros thats grand. Just a good gpu for like 400 450 euros
I would greatly recommend avoiding websites such as Kinguin. They are not permitted by Tomshardware and are not guaranteed to work. I would look into either a GTX 1060 6GB or possibly a GTX 1070 if you can afford it. Alternatively, you could wait for the new 11 series and revise your purchases to compensate for the performance boost/price drops.
is there any cheap windows keys out there that arnt 100 euros
