M MilhouseVanHouten Commendable Nov 9, 2016 65 0 1,640 Apr 20, 2017 #1 I don't know anything about hard drives so i thought i should come here. I need a 1tb hard drive that's it.
Solution USAFRet Apr 20, 2017 MilhouseVanHouten : I hate to ask, but are there any cheaper options WD Blue 7200 RPM. £41.95. https://www.amazon.co.uk/Blue-Desktop-Hard-Disk-Drive/dp/B0088PUEPK Seagate Barracuda. £46.01 https://www.amazon.co.uk/Seagate-Barracuda-Internal-Hard-Cache/dp/B01LY65EVG That's about as cheap as it gets. And well under your £80 price point.
USAFRet Titan Moderator Mar 16, 2013 179,683 22,043 184,590 Apr 20, 2017 #2 MilhouseVanHouten : I don't know anything about hard drives so i thought i should come here. I need a 1tb hard drive that's it. In what context do you need a new drive? Is this for a new PC? Or is this an addition to an existing PC? How much do you wish to spend on this? Upvote 0 Downvote
atljsf Honorable BANNED Jun 17, 2015 4,910 46 12,990 Apr 20, 2017 #3 to put inside your pc or to use connected via usb? is your pc a desktop or a laptop? Upvote 0 Downvote
M MilhouseVanHouten Commendable Nov 9, 2016 65 0 1,640 Apr 20, 2017 #4 It's for a new desktop internal pc and i don't want to spend over £80 Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,683 22,043 184,590 Apr 20, 2017 #5 MilhouseVanHouten : It's for a new desktop internal pc and i don't want to spend over £80 A "new desktop". Based on your initial question, many other questions present themselves. What other parts are you buying? What is the total budget? What will this be used for? But to your question, a WD Blue 7200RPM or WD Black. Upvote 0 Downvote
M MilhouseVanHouten Commendable Nov 9, 2016 65 0 1,640 Apr 20, 2017 #6 I'm not buying another parts. It'll be used to store data in my new computer Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,683 22,043 184,590 Apr 20, 2017 #7 MilhouseVanHouten : I'm not buying another parts. It'll be used to store data in my new computer So this is a new prebuilt PC? I hesitate to ask, but from where? What drive(s) does it already come with? Upvote 0 Downvote
M MilhouseVanHouten Commendable Nov 9, 2016 65 0 1,640 Apr 20, 2017 #8 No i built it from scratch, but i broke my old hard drive when i tried taking it out my old pc. Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,683 22,043 184,590 Apr 20, 2017 #9 MilhouseVanHouten : No i built it from scratch, but i broke my old hard drive when i tried taking it out my old pc. OK then..see my above recommendations. Upvote 0 Downvote
M MilhouseVanHouten Commendable Nov 9, 2016 65 0 1,640 Apr 20, 2017 #10 I hate to ask, but are there any cheaper options Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,683 22,043 184,590 Apr 20, 2017 Solution #11 MilhouseVanHouten : I hate to ask, but are there any cheaper options WD Blue 7200 RPM. £41.95. https://www.amazon.co.uk/Blue-Desktop-Hard-Disk-Drive/dp/B0088PUEPK Seagate Barracuda. £46.01 https://www.amazon.co.uk/Seagate-Barracuda-Internal-Hard-Cache/dp/B01LY65EVG That's about as cheap as it gets. And well under your £80 price point. Upvote 0 Downvote Solution
M MilhouseVanHouten Commendable Nov 9, 2016 65 0 1,640 Apr 20, 2017 #12 Thank you so much Upvote 0 Downvote
