Allright, how can he re-flash it if it cannot even boot???
But I know a solution...I have never personally tried it and I don't take any responsibility from what follows but hey, if the mobo is already fuNked up it's worth the try... I've seen it working on pentium one mobos, but never had the chance to try on newer systems...
I am not sure about your motherboard, but if your BIOS chip is the classic rectangular one which is also removable (hey, I don't remember its correct name... I did my Aplus a while ago 🙂 then keep reading...
1-Get an old floppy cable or ide cable and cut off a piece of about 10cm x 1cm...of course the long part must be cut parallel to the lines of the grey wires...you should wind up with something like this:
2-Get the same exact mobo somewhere, maybe a friend, maybe another store (make sure that you can return it after the job)...
3-Very carefully remove the bios chip from the new mobo, place the rectangular piece that you just cut off on the base between the two lines of pins and place again the bios chip in its original position, but leave it half-way out, don't press it all the way down.
3-Very carefully remove the bios chip from the "old" mobo, the one that has been flashed incorrectly and keep it ready.
4-Install the new mobo, and do all the steps that you would do to flash its bios (use the right bios image, this time ;-)...but stop right before the last warning, right before flashing it.
5-Now the delicate part: remove the bios chip from the mobo that you are flashing (yes, with the computer running), and make sure you do it EVENLY!!! Use the two edges of the 10cm piece of cable and very carefully remove it. The computer will more likely keep running, at least I've seen it on pentium one's mobos, and insert the "corrupted" chip half way in. If you are lucky, you will be able to finally press ok and flash the corrupted bios correctly!
6-Now put the chips into their respective mobos, return the new one and enjoy your newly flashed motherboard!!!
Good luck, let me know
A television may insult your intelligence but nothing rubs it in
like a computer.
