I need a motherboard that supports my parts.
marcin00019
17
I need a motherboard that will support these parts and the cost of the motherboard cant exceed 100euro incl shipping.
Here are the parts I need the mobo to be compatible with
FX 8350 8x4ghz 125W
PSU cx750 corsair
Radeon HD 7850 2gb sapphire
4gb ram ddr 3 1600mhz
Sata 2 slots (although I heard sata 3 slots can operate sata2)
If there is anyway for the motherboard to be microATX it would be much better for me but I dont mind buying atx as long as its 90euro or below.
ALso if you guys could tell me if this is what I am looking for
http://www.ebay.ie/itm/Mainboard-ASRock-970-Pro3-R2-0-Sockel-AM3-USB-3-0-/190945279352?pt=LH_DefaultDomain_77&hash=item2c7539bd78
The motherboard you provided would work. The Asrock 970M Pro3 , if not the ASUS M5A78L-M LX PLUS are two matx boards that will work fine. not sure on the price
The ASRock you've selected has a Power Phase Design of 4+1, which is ok. Since you've a beefy FX 8350 with 125W TDP, I would suggest a motherboard with better 8+2 Power Phase Design. Please consider this, which meets all your requirements and its a quality ATX board:
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard (€90.76 @ Amazon Espana)
Total: €90.76
Generated by PCPartPicker 2015-05-03 21:54 CEST+0200
(OR)
You could save a couple of euros and get this, which has a 4+2 Power Phase Design, which is still better than the ASRock. It's a budget crowd's favorite choice for FX 8350:
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard (€82.40 @ Amazon Espana)
Total: €82.40
Generated by PCPartPicker 2015-05-03 22:10 CEST+0200
Cheers!
I will buy the 970m pro3 asrock since its an mATX card and that is what I would prefer because if I get an ATX card I need to buy a new case to fit the board inside which would cost me another 40 euro and I don't have that much . Thanks.
