C countrygirl312 Prominent Aug 9, 2017 2 0 510 Aug 9, 2017 #1 I have a Toshiba Satellite A105-S2717 and I need a new battery. My question is what capacity does it need to be or does that not mater?
Solution alexoiu Aug 9, 2017 Check the picture and see if matching yours. https://www.newegg.com/Product/Product.aspx?Item=9SIA3RE18K6145
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Aug 9, 2017 Solution #2 Check the picture and see if matching yours. https://www.newegg.com/Product/Product.aspx?Item=9SIA3RE18K6145 Upvote 0 Downvote Solution
S sizzling Titan Oct 18, 2006 27,224 3,268 112,240 Aug 9, 2017 #3 I'd suggest always buying genuine OEM batteries. The compatible ones are not guaranteed to work even if they claim they are and very often use low quality cells that die after a short while. Upvote 0 Downvote
