https://www.amazon.com/Wraith-Cooler-Processor-AM4-Connector/dp/B07GKRR5WRHi guys am in need of help.I need new led fan for cpu but can't seem to find one for my motherboard.
Budget £60.
Even if it's just the led fan that will fit on my heatsink which is a AMD stock.
This is my one atm.
Amazon
my cpu is AMD Ryzen 5 1600 six-core Processor
I have fans using led and the cpu fan is only stock without led.this cooler you want it is only for the led or you want to overclock cpu .
Fan must be at least 2000rpm maxOh i get it now.
Hm,what do you think about this one ?
I only have D.O.C.P or D.O.C.P Standardalso for cpu did you enable axmp in bios for ram .
ok with cpu back to default factory speed activate ram docp apply you see a raise in cpu speed apply then only after that you could start to raise the multiplier but watch on for voltages and temp to do not overpass safe specs .
Budget £60.
This is my one atm.
Amazon
ok you got me hooked ,the rpm on that fan is fast 2700rpmhttps://www.amazon.com/Wraith-Cooler-Processor-AM4-Connector/dp/B07GKRR5WR
Should drop your temps by about 10C.
