S samuspunk Reputable Oct 19, 2015 95 0 4,660 Dec 12, 2015 #1 I want to know which of this two PSUs is the best and why. I have a I5 3450 and a sapphire R9 280 OC.
Solution rayzaldy Dec 12, 2015 You don't need that many watts for a single card. Just grab a quality 500w like the MaxPro or the coolermaster V550
rayzaldy Distinguished Feb 14, 2015 348 0 18,910 Dec 12, 2015 #2 Grab a Enermax 500w it will run every single card just fine. I also have it 😀 Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Dec 12, 2015 #3 Neither , both are very poor quality wise. Upvote 0 Downvote
rayzaldy Distinguished Feb 14, 2015 348 0 18,910 Dec 12, 2015 #4 Neither , both are very poor quality wise. Isn't the Enermax MaxPro a good power supply?? http://www.guru3d.com/news-story/enermax-maxpro-the-quietest-long-runner.html guru3d said they do though. just make sure he live in the uk not in the us Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Dec 12, 2015 #5 If those are the only 2 choices , I would go with the Enermax. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Dec 12, 2015 #6 http://www.aquapc.com/loja/produto.php?p=12327 COOLERMASTER V550 VANGUARD 550W Upvote 1 Downvote
S samuspunk Reputable Oct 19, 2015 95 0 4,660 Dec 12, 2015 #7 Why do you say they are poor quality? I´ve read that te enermax is good quality, with japanese nippon chemi-con capacitors and good components. Upvote 0 Downvote
S samuspunk Reputable Oct 19, 2015 95 0 4,660 Dec 12, 2015 #8 rayzaldy : Neither , both are very poor quality wise. Isn't the Enermax MaxPro a good power supply?? http://www.guru3d.com/news-story/enermax-maxpro-the-quietest-long-runner.html guru3d said they do though. just make sure he live in the uk not in the us I live in Spain and I´ve read that it´s a good psu. Upvote 0 Downvote
rayzaldy Distinguished Feb 14, 2015 348 0 18,910 Dec 12, 2015 #9 Maybe he mistaken it as another enermax psu since there are a bad enermax power supply Upvote 0 Downvote
S samuspunk Reputable Oct 19, 2015 95 0 4,660 Dec 12, 2015 #10 What about the antec hcg 620 EC? I can buy it for about 80€ Upvote 0 Downvote
rayzaldy Distinguished Feb 14, 2015 348 0 18,910 Dec 12, 2015 Solution #11 You don't need that many watts for a single card. Just grab a quality 500w like the MaxPro or the coolermaster V550 Upvote 0 Downvote Solution
