Hello.
I am about to buy a new graphics card this month, and I already know which one (MSI GTX 770, to play the latest games at a great setting), but unfortunately, my power supply would not be able to hold the new graphic card's 250 watt up.
My current power supply is a (Dell built-in I believe?) Chicony CPB09-001A, with 350 watt. It's enough for my current graphics card, which only needs 140 watt (or something), but not for my new one.
My stepfather told me that there *might* be problems fitting it inside the cabinet, which is a Dell Cabinet XPS 8100. And that I couldn't just put every power supply inside. Do any of you know of that?
The Chicony power supply's measurements in millimetre:
Width: 140
Height: 85
Depth: 150
Also, would I be able to buy any power supply with these measurements? How about the cables and stuff?
Also, I've heard Corsair is a good power supply 'brand', but I don't know?
All in all,
I'm looking for a power supply which has around 750W, which should fit inside my Dell XPS 8100 Cabinet, with the measurements mentioned above. Any of you know of anything? I try to keep my budget at max 100-120 dollars, but I don't mind saving some money.
Sincerely, Niklas.
Edit: I remembered about my motherboard, any before anyone asks what model it is, I have a Dell, which is OEM, so what I can tell you is that my computer is a Studio XPS 8100. My computer is 64 bit, if that information is needed.
Width: 140
Height: 85
Depth: 150
All in all,
Sincerely, Niklas.
