I need a PSU to fit my case
TaintedG
87
Hi, I need a power supply for atleast 400w but I'd like 500 watts.
I believe the dimensions of my current power supply is
5.9 W x 3.4 H x 5.5 D - Inches
Do you have any recommendations?
Any ATX form factor should fit your case. They are std on width and height but can vary in length. An Antec 520watt http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
Guysss forget all my previous questions. I realized that I gave the wrong old PSU
I'm wondering whether the power supply that I'm buying
(http://www.corsair.com/builder-series-cx500-v2-80plus-certified-power-supply.html)
has all the connectors that my old PSu has;
24 Pin ATX Connector
4 Pin ATX12V Connector
(4)4-Pin Molex Power Connectors
(2)Sata Connector
(1)4 Pin Connector - Power Floppy Drive
The only one I noticed that isn't there on the new psu is the 4 Pin ATX12V Connector. Is that true? Would I need another PSU that has one?
