I need some advice here as I can't seem to figure out what I'm looking for.
I currently have a 1280x1024 native display. It a septure brand and has served me well for years, but its has several issues that bother me. 1. Greys always have a slight color cast (and adjusting doesn't seem to help) , and the black is uneven, bleeding from the cathodes at the sides.
So I want a new one, but I'm not sure what resolution will work best for me. I want either 1900x1200 or 1680 x1050, but when I went to my local best buy all, yes every last one, of their larger monitors were 1900x1080. There wasn't a 1900x1200 unit in the store.
I use my computer for 3D graphic arts, and gaming. Thus I need the tricky combo of decent color accuracy with a decent response time. I'm most likely not going be watching TV or attaching an xbox to my monitor.
Obviously graphic arts programs could care less about the resolution for compatibility. Its the gaming I'm worried about.
So my question is thus, is a 1900x1080 monitor compatible with games in native resolution, particularly some older games like STALKER SoC, HL2, or KOTOR? Seems like newer games will be, as 1080 monitors is are going to be all you can buy, but I'm curious if I'm wandering into bad thing buying a 1080 monitor.
I'd also like to know if 1080 monitors are good as they seem to be much cheaper than WUXGA 1200 ones, so they are attractive for a dual monitor solution.
If anybody could shed some light on this, I would be thankful
