[SOLVED] I need a recommendation for a new monitor
Jan 28, 2019
Hello could someone recommend a new monitor for me?
I'm going to using two computers with a single monitor. I need the ability to switch between input sources really quickly, ie there needs to be a source button on the monitor
I need 2 x HDMI ports and maybe a VGA port or DVI (not that bothered)
Monitor must be cable of 1080P resolution
Needs to be under £200
Thanks that looks great. However the imsage isn't very clear - I dont see a button that can change input source.
I don't want to go through a menu system to do this. There needs to be a dedicated button to switch between sources.
27inch is exactly the size I'm looking for. It won't be used much for gaming, primarily for browsing the web.
