I need a small PSU
mrnarwhal
8
I have a small case and need a 400w or more PSU thats no bigger than 7.5 in x 3 in x 3.75 in. I can't find one online. I'm assuming I need mini itx, micro atx, or flex atx. Anyone have any leads? Thanks.
That graphics card is fine.
All of those TFX PSUs, that you've linked to, are generic garbage. They only have a maximum combined +12 Volt continuous current...
Is it a TFX form factor PSU?
TFX
• Standard dimension for this form factor is:
85mm (W) x 65mm (H) x 175mm (D)
3.35in (W) x 2.56in (H) x 6.89in (D)
• There are models with varying depth, but usually shorter than 175mm
What's the full system specifications?
I have an intel i5-2400, lenovo is6xm motherboard, 16 gigs of ddr3 ram (I know its overkill but I had it so), . I'm currently running the integrated graphics, but I'm looking to upgrade, hence the need for a 400w PSU. Currently for PSU I have a fsp group inc model fsp240-50 sbv. I'm working off an old Lenovo M91P I got for really cheap from an auction (and mainly got just for the CPU).
I'm concerned about that width. Here's a picture of what it is on mine
I was thinking about a GT 740 or GTX 750 TI depending on how much the new PSU costs, or just how much money I generally have.
Do you think any TFX would be fine? And if so, is there a 400 watt one?
System Power Supply Requirements for a single GeForce GTX 750 Ti
NVIDIA specifies a minimum of a 300 Watt or greater system power supply. (Minimum system power requirement based on a PC configured with an Intel Core i7 3.2GHz 130 Watt TDP processor.)
the system power supply must also have a maximum combined +12 Volt continuous current rating of 20 Amps or greater
the system power supply should also have at least one 75-Watt 6-pin PCI Express supplementary power connector for some of the non-reference design cards (e.g. ASUS GTX 750 Ti OC 2 GB [GTX750TI-OC-2GD5], EVGA GeForce GTX 750 Ti FTW w/ EVGA ACX Cooling [02G-P4-3757-KR]).
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Sufficient Total Combined Continuous Power/Current Available on the +12V Rail(s) is the most critical factor.
FSP GROUP INC. 240W (FSP240-50SBV)
OEM: FSP
maximum combined +12 Volt continuous current rating: 17 Amps <===== Sufficient depending upon age of the PSU
No PCI Express supplementary power connectors
Modular Output Cables: No
Official Intel Haswell Compliance: No
• No 80 PLUS Efficiency Certification
If you want to replace the PSU get this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151114
I wanted this GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836&cm_re=gtx_750_ti-_-14-127-836-_-Product
It says I need a 400 watt power supply. Would any of these fit my space?
http://www.newegg.com/Product/Product.aspx?Item=9SIA7252X26472&cm_re=400w_tfx_power_supply-_-9SIA7252X26472-_-Product
http://pointtek.ecrater.com/p/11544816/hp-pavilion-slimline-s5660f-power
http://www.outletpc.com/wr4972-replace-power-rp-tfx-420-tfx-12v-420w-psu.html
http://www.ebay.com/itm/Replace-Power-Supply-TFX-SFF-420W-watt-Upgrade-for-250W-300W-320W-350W-400W-/281281781299
All of those TFX PSUs, that you've linked to, are generic garbage. They only have a maximum combined +12 Volt continuous current rating of 14 Amps. They won't work. That's way worse than your current FSP240-50SBV. Don't be duped by a liar Wattage value.
You should be asking yourself why a 400W PSU's +12V rail is much weaker than your current 240W PSU.
This SeaSonic SS-300TFX Bronze has a maximum combined +12 Volt continuous current rating of 21 Amps and is way more than enough for your system configuration:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151090
awesome thanks
