[SOLVED] I need a smaller ATX Power Supply
Oct 14, 2020
23
Goodmorning :)
I've bought a Kolink Satellite and if I want to put a longer GPU (longer that 190mm) I need a smaller ATX PS. It shouldn't be longer than 140mm. I noticed that my old Enermax Modu 82+ fit perfectly, but its 525W and with my system I need at least 700W. Of course I need a PS that is fully modular. Any suggestions? :)
THANKS!
Goodmorning :)
THANKS!
You can get SFXL power supplies at up to 1650watts nowadays.
Goodmorning :)
THANKS!
Sadly the Silverstone I found is 600W and I don't think it's enough (Now I run a 1060 3GB but I am planning to get a RX 6800 or a RTX 3070). This one could be the right solution: Corsair SF750 80PLUS Platinum, Fully Modular Power Supply SFX - 750 Watt
Thoughts about it?
