I need a soundbar that uses coaxial cable hook up to tv. Does anyone know of any?
jonmestep123
I have a sanyo 50 inch hd plasma tv model DP50741. It only has coaxial cable hook up for a soundbar. Does any one know of a soundbar that is compatible with this tv?
think I might have missed some information - typically, you're going to run the coax connection from the wall outlet your cable provider (or antenna) uses to your TV, then you're going to run components or HDMI cable(s) between your TV and sound bar (or a optical cable for just audio) to pass video/audio.
