i need a step by step guid how to install a fully modular power supply
connar
48
hi i had a cmx1000 and i got that installed by a mate and it died about a month ago so i bought a seasonic p-serie 1050w fully modular psu but i need a step by step guide how to install it i have a half decent under standing about a PC so yea it would help if you have pics but i can do it without pictures thanks
Not too tricky, hopefully this picture and description will help
The two amber arrows point to where your 24 pin connector will go (into both)
The green circled headers (6 pin) are for your SATA and Molex cables
All 8 pins are for the 8 (or 4+4) pin CPU connector or PCIe (graphics) connectors
There is no particular spot for any of those (other than the 24 pin) so I suggest populating them in the PSU as you see fit
