I need advice and analysis on this build
digitalbl00d
9
http://ca.pcpartpicker.com/user/digitalbl00d/saved/4z4Zxr
This is the new pc I want to build.My only limit is that each part must not exceed 250$ CAD.I'd appreciate any input and recommendations on how I can improve this build and have the most out of it for a good price.Thats the reason I chose the GTX 750 TI and the AMD FX-8350 4.0GHz 8-Core .I have little to no knowledge of anything that seems likes pc engeneering (overclocking, heatsink stuff and cooling).Also could take suggestion for a good monitor/tv that work super with the graphic card.At the moment I have a 32po element "hd" tv with which I had many weird issues I never imagined could exist. (this one http://www.elementelectronics.com/products/eleft326/ )
Get normal home edition windows. You get nothing from Ultimate. It is just marketing. I also recommend 8.1 over 7. I prefer it and use it on all my machines. It is faster and easier. Plus it is rumored you get a free upgrade to 10 instead of just having to buy and reinstall it in 6 months.
three fans is plenty. front intake, rear exhaust, and top exhaust.
CAD as in Canadian dollars.And as for 3D modelling thats a thing I once planned to learn , so I could as well say yes as well. So every other part I chose are good? Do I need cooling or something? I wouldnt want anything to overheat. Also for the case fans what is best outtake or intake? Or both?
Is the soundcard bad?I also happen to be making music,not professional of course,but a good sound card make things better for this kind of usage.LAN,well does the motherboard have ethernet on it?sometimes wired can be needed,I'm not trying to save maximum money, I just wanna know if something is really bad,and why should I remove or change it,and if I change it,with what.And what PSU is quality?I went with the amount of review and star average on pcpartpicker.If its rated 4.5 star or more and has ton of review,I see the product as being good enough and reliable.But maybe I'm wrong?
Edit: didnt see other reply sorry
The on board sound card has a very good quality OP amp included in the chipset so honestly unless you are editing professional level audio with $250+ mic and $250+ headphones you will never even see a subtle difference.
ALL motherboards have wired LAN connection included. NEVER buy an additional card.
For the PSU stick with Antec, XFX, Seasonic. That Corsair is junk. It has "fake good reviews" from people who are not used it long term. they have poor caps and fail all the time. NEVER recommended for a build like this.
Thanks for the suggestion I've changed my parts:
So for the case fans...how many fans I need with this setup? , is this case alright for this setup?If I need more than 1 fans, do I need at least 1 intake and 1 exhaust?Or just do exhaust OR just intake (not both).I never saw a "build it yourself" pc. and normal pc only has 1 exhaust fan on the back usually..if I'm right, but that is probably not enought with custom part I suppose?
Also, I would like to find a Monitor that has at least 2 HDMI, 22po or larger,with audio output (for speaker) as I plan to use it with my PS3 as well.I changed the monitor according to response rate but couldnt sort and filter the list of monitor to include how much HDMI I want and feature like I stated.
Okay good , I have win8 on my acutal desktop I like it but I liked win7 too but so far I have no prob with win 8 so yeah I will go with win8 again.And okay I will see if I can install 3 fans,maybe my case is not made for 3 fans thought.If it isnt can you link me to one I could use for 3 fans.
Also thank you for your time and answer IF you would like when I will have all the part and have it build I will post a pic of it and review it :)
