I need advice or help for LCD 22" or 24",
omsg
4
1) What is MIN requeriment of Video Card => LCD 22"?
2) What is MIN requeriment of Video Card => LCD 24"?
This LCD can work with my PC? Please read characteristics of my PC.
The characteristics of my PC are:
1) Motherboard: ABIT Fatal1ty AN8-SLI Socket 939 NVIDIA nForce4 SLI ATX AMD with ABIT Guru Controller Panel.
2) Processor: AMD Athlon 64 X2 Dual-Core 3800+
3) Memory: Kingston ValueSelect 2 GB (2 x 1024 MB) DDR 400 (PC 3200) ValueRam
4) Hard Drive: SATA 120 GB Seagate 7200
5) Video Card: PCI Express XFX Geforce 7800 GTX 256 MB DDR3 with AC (Arctic Cooling) Accelero X1 Fan: 60mm - Bearing: Fluid Dynamic Bearing.
6) CD / DVD Burner Black: LG Black E-IDE / ATAPI DVD Burner 5X DVD-RAM Write Model GSA-4167B BK.
7) Creative Sound Blaster Audigy-2 ZS 7.1
8) Power Supply: HIPRO TOP-600P5 ATX V2.01 600W
9) Case Black: Satellite X-BLADE(Games)511 with CPU Temperature Automatism Control System(Digital Display with temperature sensor) and Double 8 CM System Fan(Three Fans (2 with lights Neon)) - 2 ports 2.0 USB with entrance
for headphones/earbuds and microphone.
10) Drive Black 1.44.
11) Expansion Slot Rear Exhaust Cooling Fan.
I wait answer.
<s>
Depends on your budget. I general recommend an Intel C2D of some model depending on how much you want to spend.
If you are on a budget, then go with a socket AM2 Athlon 64 X2.
If you are into overclocking, then definitely go for an Intel C2D.
You can also post this question in the CPU section. It's always good to get different opinions.
enendar: thank you. I not can buy from this shop because I live in Paraguay (South America). Others shop's accepy shipping to Out USA.
<S>
