I need Advice what fans and cooling should i have for my pc case
Joaquin Andrei
13
Specs:
Processor: Intel Core i5 4460
Motherboard: Asrock H81-M DGS
GPU: GTX 1060 armor 6gb OC
Ram: 2x8gb kingston Fury X
PSU: Seasonic m12ii 750 wats Bronze modular
here are my heatsink fan i think its deepcool but i dont know what version http:// and with the stock fan comes with the case here is the link http:// http:// can anyone suggest me what should i use liquid are coolers? or just hsf and also im not into overclocking really and when i play games like gta 5 , rise of the tomb raider it gets hot and i reach 70c while i play tomb raider on my gpu i think that's why it cause hot on my case and im using gtx 1060 6gb armor and im just using hsf and a stock fan so anyone would suggest that would be awesome:bounce: :D:lol::love:
Dark Lord of Tech
темный лорд технологий
Should be perfectly fine with that heastsink , but you could gain a couple of degrees cooler in temps by having the fan push air thru the heatsink from the other side instead of pulling.
70c isn't that hot they have a thermal ceiling around 94c.
Joaquin Andrei
13
but my pc case is hot is that normal?
Joaquin Andrei
13
im just using a stock fan that came from the case which is at the back place and here is my plan http://
af120 and h100i v2 but i think i dont need expensive aio if im not overclock any advice
Joaquin Andrei
13
so af120 on the back and the front are fine? and can i do af120 as exhaust ? and also is it fine and no drawbacks if i put it on the top as exhaust and also on the back and will it cool down the temps of my system with just af fans?
Joaquin Andrei
13
can you explain me much more about sp120 why i should use and when and also the af120
Joaquin Andrei
13
so 5 af120 2 in the front as intake and 1 on the back as exhaust and 2 on the top? will it help to reduce my temps?
Joaquin Andrei
13
can you recommend me some parts that i need to buy i dont want to just buy because if its not exactly will help on my temps i will just spend my savings on another plan
