Hi all,
i'm wondering that my system's temp is ok better or high and if its high then what kind of solution i need to get.
GPU Gigabyte GT 640 2 GB DDR3(company OC version)(stock fan and heat sink)
Temp:31-34c in day time 29-32c in night time.(when not working).
Temp after gaming.42c tops till now.(drop to 30c in 10 seconds after)
CPU i7 2600 3.4ghz sandy bridge(non-overclocked)(stock fan and heat sink)
Temp: 36-40c day and night time (when not working)
Temp After gaming temp 42-50c (drop to 39-41 in 10 seconds after)
(fan running at full rpm 2000-2700 24/7)
Case : Gigabyte Somo Alpha (side panel steel mash) 3x120mm(stock fans)
1.intake from front running at 1100-1490 rpm 24/7.
2.exhaust 2x120mm on top vents, one running on 1100-1490 rpm 2nd 2000-2800 rpm 24/7
PSU corsair VS 550 120mm stock fan facing casing floor vent so no act participation in internal casing air flow.
Plz advise.
Plz advise.
