I need an advice
ovidijusp473
25
Hello curently im using nvidia 9800gt i know its an old gpu but i was thinking about its time to change it. So ive been thinking and i dont really know what type of case it is cause the case is pretty old. Could you recommend me a gpu for about 70€. Thank you.
Well, that's not a very good power supply. Either go with a GT 1030 or increase your budget and get a new, better quality power supply and a better GPU.
Nvidia Geforce 9800gt
Amd Phenom 9950 x4
4b ram
M3A78 Asus DDR3 SATA2 MOBO
350W or 500W i think
500gb hard drive
My pc is pretty old but it works great just want to get a better gpu.
With your current budget a GT 1030 is the only new card you can consider.
I'm not sure how the used market is where you are, but if you can find a or GTX 660 or HD 7850, it would be better than a GT 1030.
But those cards are aging as well and you don't necessarily want them dying on you anytime soon. Maybe save up a little more cash and try and get a GTX 1050.
The power supply is star tronic pentium p4 pfc model st 500cpba
The power supply is star tronic pentium p4 pfc model st 500cpba 480w im pretty sure
Thank you for your answer.
