[SOLVED] I need an idea for a pc build around 850$
Jan 21, 2019
5
I would like to have a i7 of any kind but I know it’s highly unlikely for this price point I at least want any i5 cpu a gtx 1070 or 1080 gpu 8-16gb of ram I don’t care what power supply as long as it will support it that’s all the specific things I would like if possible the rest of the parts are up to whoever can help me find a build I just want something to run Skyrim/skyrim special edition with enb 1080p I already own a 144hz omen monitor I need help with a pc build
$850 I assume you are from the united states?
a bit over budget,
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor ($304.99 @ Amazon)
CPU Cooler: Deepcool - GAMMAXX 400 74.34 CFM CPU Cooler ($16.89 @ OutletPC)
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard ($72.98 @ Newegg)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory ($89.99 @ Newegg Business)
Storage: ADATA - Ultimate SU650 240 GB 2.5" Solid State Drive ($32.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 8 GB Windforce OC Video Card ($299.89 @ OutletPC)
Case: Rosewill -...
a bit over budget,
Case: Rosewill - FBM-01 MicroATX Mini Tower Case ($24.99 @ Amazon)
Power Supply: SeaSonic - S12II 620 W 80+ Bronze Certified ATX Power Supply ($39.99 @ Newegg)
Total: $882.61
Generated by PCPartPicker 2019-01-21 09:56 EST-0500
if you go with a i5 8400, you can pbbly save around $100, and likely would not need an aftermarket cooler.
CPU: Intel - Core i5-8400 2.8 GHz 6-Core Processor ($193.89 @ OutletPC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard ($69.99 @ SuperBiiz)
Memory: ADATA - XPG GAMMIX D10 8 GB (2 x 4 GB) DDR4-2666 Memory ($49.99 @ Amazon)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive ($82.99 @ Newegg)
Video Card: Zotac - GeForce RTX 2060 6 GB GAMING Video Card ($348.99 @ SuperBiiz)
Case: Corsair - SPEC-05 ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $835.83
Generated by PCPartPicker 2019-01-21 09:58 EST-0500
