I need cooling help!!!!
avenged_guitarist
36
Ok, so I'm building a gaming computer and I've decided all the parts I'm going to get except the cooling system. I need help figuring out which kind of cooling to get (air, water, liquid) and once I figure that out I also need help help deciding weather to get a pre-made kit or to build it myself, getting the parts separately. Here is a list of the parts that are going to be in my computer
-CPU-Intel Core i7-3930k
-Motherboard-ASUS P9X79 Pro
-RAM-Corsair Vengeance, 4 sets of 16gb dual channel DDR3 memory
-Hard Drives-2 Western Digital Velociraptors 1TB
-Graphics Card- EVGA GeForce GTX 580
-Monitors-3 HP 2511x 25-inch LED monitors synced together
-Case-Bitfenix Colossus Venom
-PSU-Silverstone Strider Gold ST85F-G 850W modular power supply
-Sound Card-ASUS Xonar DX PCie 7.1 sound card
-Keyboard-Logitech G19
-Mouse-Logitech G700
-Optical Drive-LG 22X Super-Multiple DVD-Writer
-Operating System-Windows 7 Ultimate
I don't have a budget for this computer so i want to get the best of the best. Any help is welcome
randomkid
First, you need to reconsider the "RAM - Corsair Vengeance" because they have high profile heat spreader which may cause obstruction if you use air cooler. If you decide to go liquid, then it should be safe.
Here are good readings for you that pretty much sums up the best options for air cooling:
http://www.frostytech.com/top5heatsinks.cfm
http://www.tomshardware.com/reviews/LGA-2011-i7-3960X-Air-Overclocking,3130.html
Make a shortlist & zoom in on each.
CM_USA
141
Hyper 212 Evo is the best fan for its price.
http://www.cmstore-usa.com/hyper-212-plus-universal-direct-contact-heat-pipe-cpu-cooler/
You can also look at all other available coolers. Here are the available coolers in CM-USA store.
http://www.cmstore-usa.com/cpu-air-cooling/
mace200200
I run a hyper-212- it's really as good as they come for the price in heatsinks. Keeps my cpu at 51C at the highest and i don't even have as second fan on it yet.
dannoddd
241
You don't need liquid cooling and it has no bearing on monitors, hard drives, or RAM. BTW, the closed loop ALC systems like the H80 aren't "really" liquid cooling.
A good air cooler will do you just fine. I really like the towers from Noctua, as they are efficient and quiet. They are expensive though.
I do agree with reading that Tom's article about coolers. Great article. The other thing is a unit like the H80 or H100 will match temps of the high end coolers, but do it a lot louder. They are smaller though.
Definitely consider getting low profile RAM. Corsair makes a low profile Vengeance line, BTW.
If you're getting best of the best, ditch your GTX580. The GTX680 and 670 are out, as well as all of AMD's HD7XXX series. Look at those for your GPU.
randomkid
If you are not overclocking, the stock cooler is fine. Take heed of dannoddd's advice about the GTX580 & consider the 679 or 680. They are the cutting edge of graphics card today & better match the rest of your components. If you have chosen the i7-3930k platform for gaming instead of the more cost effective i5-2500K, the money is most probably no object.
dannoddd
241
CPU frequency is determined by base clock times multiplier (Bclk*X)
With an unlocked multiplier "K" series, you raise the multiplier and use programs like Prime95 or Intel Burn Test to test for stability. If you blue screen, lock up, or crash, you need to stabilize voltages, but very carefully raising those.
Heat is the enemy, so an overclocked processor is the balance between speed, voltage and temp.
If you're on a Non-K processor, you have to raise the Bclk, but usually can only get about 5mhz from that, if lucky.
